Why does my Balance Board turn off randomly?
My Balance Board keeps turning off randomly. In the middle of my game the balance board will suddenly power off. What is wrong?
Это хороший вопрос?
Это хороший вопрос?
If you are playing a game and the balance board shuts off, then it might be that the battery connection is breaking. First check to make sure your balance board is running on fresh batteries. You also want to ensure the battery terminals are not corroded. If the problem persists, then you might need to replace the Battery Case.
The second option is to check the motherboard. It might be damaged and in need of replacement.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 34
За всё время: 4,616
1 Комментарий
My problem is. My balance board will not switch off. Constantly on . Battery light goes off when charging but soon as I unplug charger it switches on . Is this main board problem?.
Also what's the difference on the main board one is blue & one green?? I have herd that blue logic board is the better make? But can any one confirm this.
из Larry armstrong
