Первая модель iPhone. Модель А1203; с 4, 8 или 16 ГБ памяти; и алюминиевой задней крышкой. При ремонте придется помолиться и немного попаять.
224вопросов Показать все
Water drops fell on it, and now it only works on power!
Hello guys, i am desperate about my iPhone.after some drops of water that i had at my ear while talking,the iPhone stopped working. when i then connected the phone at the charge i saw it booting and thought it was ok....but every time i disconnect it freezes..and forcefully shuts down. i opened it and sprayed some contacts spray all over let it dry with rice etc.. and still the same. should i remove everything and spray it thoroughly an everywhere? what could be the problem. i checked the battery and has voltage so i think it is not that
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
You may have
corrosion inside, you may have shorted the battery. Look through these answers especially ones dealing with water and battery.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Theodor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,237
