I HAD the exact same problem. I did some research, tried a whole bunch of different stuff and even considered buying a new battery (since I too have left my phone charging overnight on many occasions), and if that didn't work, I would replace the USB port.
But first, I decided to simply CLEAN the USB port. I removed the battery, then I used a plastic dental pic to pluck out any dirt and debris. Then I folded the corner of a paper towel into a sharp point, dipped it in alcohol and rubbed it all around inside the port to remove any oxidation on the internal prongs and central metal tab. Next, because plastic isn't strong enough, I used a METAL dental pick (again, dipped in alcohol) and very, very slightly BENT the metal tab more to the " inside center" of the port by sort of rocking it back and forth, again, very slightly. You definitely do NOT want to BREAK it! Lastly, I replaced the battery, plugged it in and VOILA! It began taking a charge! I charged it to 99% and unplugged it. That was yesterday. This morning, with the phone at 35% , I plugged it in to top it off, but AGAIN it would NOT take a charge. So, I repeated the tab bending process from yesterday and it is NOW CHARGING AGAIN.
The bottom line, it seems to me, that BLU phones have a really cheap and crappy USB charging port, that's all.
I suggest: 1) Never over-charge your battery. 2) Download a Battery Charge Notification app.
If you don't happen to have a metal dental pic, I suppose you could use a thin metal nail file, or perhaps very thin tweezers. Hope this helps all who suffer this cell phone nightmare. (excuse the hyperbole).
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
11 Комментариев
my blu studio 7.0 is just about one week old and it takes like two days to fully charge and when it is full charged it does not hold the charge for long, doesn't even last the days if i use the phone alot
из yoshi6980
my blu studio 6.0 which is biult in battery is not taking any charge and when it does pop up that it is charging it move up to 1% and this is countious.Even sometimes the battery will drain while charging .This been happening for over a week now and i really need answers.
из Alex Thompson
my blu studio 5.0 is now two days old and when i plugged it in to charge today it wouldnt charge.....
из lana jay
So this is what I learned. Happened at the wrong time. Open the device carefully. On the USB port you'll see glue that prob dripped on from the casing . on my viva air it was black in color. I think these Chinese phones have bad or no QA. As u use the devices excess glue drips down over the solder points and causes the device e to not charge. Use rubbing alcohol. To remove the black glue. When I put it back to gather the captive buttons stopped working. There was also black glue on connector port. Once clean the device will work till u bust the screen like I did :)
из Eric Noriz
Oh shoot wrong post to wrong board. Im use to explaining why these phones stop charging .
из Eric Noriz
Показать 6 больше комментариев
