I had a very similar issue.
I put in a blue-ray disk and went to pause it, but hit stop by accident. My Xbox froze and so I turned it off and back on. This led to whats known as the black screen of death.
Fixes include a hard restart where you hold the power button until it turns off and then you turn it back on. I unplugged it until the power light on my power brick went out. I even power cycled the xbox by both the power button and the outlet. Nothing worked.
A lot of times when an electronic system freezes it is a sign of overheating, which if you read other forums that tends to be the case. Even earlier answers involve reducing the stress on the system by unplugging drives.
So to fix the issue indefinitely
1. Open the xbox case via diagrams and instructions
2. Once open remove the cooler from the CPU.
-You will notice that the heat sink paste will look like dried play-doh.
3. Clean old heat sink paste off with rubbing alcohol (90% preferred), both the cooler and CPU.
4. Apply new thermal paste to the CPU.
-Either a drop the size of a pea or use the spreader that comes with the paste to cover the entire cpu.
5. While the Xbox is apart blowout dust from the entire case with compressed air meant for computers.
6. Put it back together and turn on.
This will resolve most Black screens of death.
Был ли этот ответ полезен?
Проголосовали
Отменить
Счет
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
23 Комментариев
I have had this issue a couple of times. First time I disconnected the power and reconnected and it started working. The other time I put a disc in and it switched on. Not sure what is causing the problem, my guess is software issues.
из Dom
I am having the same issue as well. It seem to have started sincethe weather has got cold. So i have to unplug it waite a while warm my room up and plug back in then it works.. But it may be because its getting clogged with dust.. Hope this helps abd if anyone knows the real reason let us all know please.. Thanks
из Key
So im having the same problem too on my Xbox one s. So I dont have this bind button. Thoughts?
из Jason Wright
Unplug. Then plug back in. Worked for me.
из Mr. Pabst
me wont work still
из Graham Wolsey
Показать ещё 18 комментариев
