My chuck is not spinning?
Everytime I press the trigger the chuck does not spin, the battery has power, for your information. What possible things could be wrong with my drill?
Это хороший вопрос?
Это хороший вопрос?
I had a similar issue. When you pull the trigger the light came on but the chuck would not turn. No sound or smell, the chuck just didn't engage. When I took it apart I found there was a cold solder joint on the red lead to the motor which came loose.
Был ли этот ответ полезен?
The trigger switch may be bad. It might also be a bad motor or a wiring problem.
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 1,814
