The Roomba 650 is a Fourth Generation robotic vacuum released by iRobot in August 2012. This device is hand-free and is programmed to clean our homes. With little manual operation needed, this robot have revolutionized house cleaning.
28вопросов Показать все
Resistance in right wheel/"error 5"
I've been getting the "Error 5 right" message on my Roomba 650. The right wheel seems to have twice the resistance of the left wheel. I took out the wheel module, opened it up and cleaned everything out. The problem persisted so I ordered a new wheel module. Still no luck. Then I noticed something very odd: the wheel has normal resistance when it's out of the Roomba but as soon as I lower it into place the resistance immediately doubles. Even with the battery removed this happens. I've very meticulously cleaned out the wheel well and it makes no difference. I've also cleaned the optical sensors and tried doing the Spot/Dock reset. Nothing. Any ideas??
Это хороший вопрос?
Оценка 5
15 Комментариев
I have the same exact problem
из
I also have this problem- did you ever figure it out?
из
Any of you guys had any luck? I have the exact same problem
из
I called them about it and they said I need a new robot. They will sell you just the robot part for $199 and you use your own charger & battery and maybe a couple of the other parts
из
I had same problem and ordered a new wheel - still same problem. they offered to sell me the core unit for 20% off - which they said would cost around $330. I declined and returning part. We haven't used it on a daily bases so would have thought it would last longer than a year or so. :-(
из
Показать 10 больше комментариев
Добавить комментарий
4 Ответов
Наиболее полезный ответ
This is what is known as an H-Bridge driver circuit problem. It is an issue on the main circuit board. It can be fixed but only by somebody with advanced circuit repair knowledge. Replacement of the main circuit board is what I do to fix them. While relatively complex, it isn’t outside the realm of a reasonably competent DIYer. Of you can send your bot to a robot repair company. Boards are available on EBay.
Был ли этот ответ полезен?
Оценка 2
If you notice that the wheel turns freely when removed, but immediately has resistance when installed then this is an issue with the computer circuit. Possibly it got wet, and a line on the board shorted it out. if replacing the wheel module did not fix the issue, then you need to get a new computer circuit board. unfortunately, the last I checked you can’t buy the circuit board separately, but have to buy a whole new roomba minus the battery. last I checked they were selling the roomba sans battery for about $500. if you are lucky you might be able to find a board on ebay or some other outlet.
Оценка 1
I believe it is a loose connection of solder point near the plug. I used electric cleaner from radio shack and it worked again for a few seconds and then stopped. Need to figure out how to get into this area of the Roomba. Watching Youtube for the answer. Looks like the area is plastic welded shut. Either way I'll get inside for a visual inspection.
Оценка 0
I ahve tried everything for error 5 on roomba 805. Took all wheels or cleaned and reset battery … The wheel runs perfect out of the housing once in lock up again. How can I resolve this
Aaron Marquez / aaron.sleep@gmail.com
Оценка 0
Добавьте свой ответ
Chris будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 22
За последние 30 дней: 91
За всё время: 13,364
