Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
157вопросов Показать все
Вопрос закрыт
Why does my cable work with one controller but not another?
I use one main controller and one secondary one for my friend. Anyway, I was using it on my laptop to play games and I synced them together. After, I un-synced them and try to re-sync it with my ps3. However, it wouldn't work. I plugged in the cable, and the controller didn't respond at all. I tried it on the other controller and it worked fine. It wasn't out of charge, and I had reset the controller to see if that helped. I'm thinking that part where you plug the cable in on the controller is broken, so I'm wondering if and how I could fix it?
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
The charging port on the one controller is broken and need to be replaced.
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 65
