The Toshiba Tecra M2 model was useful in the business field for its lightweight design and bluetooth capability.
Вопросов 4 Показать все
Why is my touchpad not responding anymore?
The touchpad isn't responding to anything right now but I can use a mouse in the USB port. How can I fix the touchpad?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (4)
Наиболее полезный ответ
Does your laptop have a keyboard shortcut that disables the touchpad? I think off the top of my head Toshiba uses the Function + F9 key to turn on and off the touchpad. Some even had a button right next to the touchpad that performs the same function.
Был ли этот ответ полезен?
Оценка 5
Go to Mouse settings>touchpad >additional settings on the right side>>Advanced>advanced featured settings>device select>touchpad>>apply
Оценка 1
You may need to update the touchpad's driver. Which can found here at the Toshiba Software & Support page
Оценка 0
1 Комментарий:
That’s a good idea, but that’s not always the case.
из
One of the issues is that your laptop is old and the laptop dies / runs out of battery, so the mouse pad goes filty and stops working . The only way I’ve found is that you use a usb and connect and mouse to the laptop.
Оценка 0
Добавьте свой ответ
Amber Cook будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 11,085
