The Asus X551CA is a 396.2 mm laptop computer with convenient features for everyday use.
29вопросов Показать все
How to install 8GB Ram in Asus X551CA?
Hi, im planning to buy 8GB RAM memory for my ASUS X551CA laptop.
How to install the 8GB RAM Memory in X551CA Motherboard ASUS Laptop? and what is the limit of Memory Slots of ASUS X551CA Motherboard? is it 4 or 8 GB only? Thanks
Это хороший вопрос?
Оценка 3
5 Комментариев
We need the full model name like X551CA-XXXX.
из
asus xx51cap
из
email me at denznewgate25@gmail.com form ore information about my laptop :)
из
what about this one x551ca - sx014h
is upgradeable to 8gb
из
Hello
Is it possible to update RAM in Asus X551CA-SX030H?
in specification there is information that can take up to 12GB
Thank you for info
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
4 GB is soldered onto the motherboard. No slot for expansion. So if the ram is bad, get a new motherboard or just throw it away.
Был ли этот ответ полезен?
Оценка 4
I know this is an old post but online there are different answers to this question. I am adding this in case someone needs the ultimate info:
The asus x551ca-sx024h PCB rev 2.2 doesn't have any additional slot, see the pictures, in the last one you can see that the slot is empty and the RAM is soldered directly in the PCB
Оценка 2
the RAM limit on your notebook is 8GB so, you can upgrade your RAM, its really simple to change it. if you haven't bought the RAM the check this crucial link http://www.crucial.com/usa/en/compatible...
Оценка 1
The ram slot is on the bottom of the motherboard. There is no access panel so the motherboard has to be removed and RAM added.
Оценка 0
Добавьте свой ответ
denznewgate25 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 23
За всё время: 14,132
