Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382вопросов Показать все
How to fix broken LVDS video connector? iMac 2010
Hello one and all, I just tried to install an SSD in my optical drive tonight. I just ended up ripping the LVDS video connector on the main Logic Board. I ended up losing one of the pins as can be seen in the photo. My question is how screwed am I and what should I be looking into fix it? I have a few friends who are comfortable with soldering. I just need some opinions.
Thanks in advance!
Это хороший вопрос?
Оценка 1
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Soldering computer components is not like soldering lamp cords or speakers. If your friends regularly work on computers small electronics they are qualified. If not too much heat will destroy the logic board.
If your friends are not qualified a small electronics/computer repair shop may be able to help you. They may have, or have access to, the replacement connector, otherwise you'd have to obtain one by de-soldering a good one from an otherwise dead board (found on e-bay)
If this answer is acceptable please remember to return and mark it.
Был ли этот ответ полезен?
Оценка 1
me, just like machead3 stated, this is not an easy repair, but it can be done. I'd suggest to replace the connector (easier said than done, hard to find). The connector is a 20389-Y30E-01 and I believe this is compatible, but you do want to double check.
Оценка 1
https://www.youtube.com/watch?v=M4POV5jn...
Оценка 0
DT&T Computer Services Inc, $195. Imac Video connector repair.
Hopes this help.
http://dttservice.com/macrepair/index.ph...
Оценка 0
Добавьте свой ответ
me будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 5,451
