The Motorola Defy was released in October 2010, and was designed to fill a niche area of the smartphone sector.
5вопросов Показать все
Why are my phone calls not connecting?
The calls are being dropped, cannot clearly hear the person on the line, or will not connect at all.
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Phones calls may not connect if there is a poor signal or the antenna is broken. If the signal is poor, this may be because the cell reception is bad in the area you are in. If the area you are in is supposed to be good, then the antenna may be broken and must be replaced.
Был ли этот ответ полезен?
Оценка 0
Please seject me properly gauide
Оценка 0
Добавьте свой ответ
Morgan Roark будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 165
