1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201вопросов Показать все
Can this be upgraded to Snow Leopard?
I picked up an iMac at our university surplus store for $175. It works well (hey, it's a Mac).
Basic specs are: 1.83 Apple Core Duo, 1 GB 667 MHz DDR2 SDRAM.
It's got Leopard but I'd like to upgrade to Snow Leopard (as well as iTunes 10.6) if possible.
My plan is to get it ready as a Christmas present for our god son who just stared high school (his mom wouldn't be able to afford a new iMac and he'd prefer Apple over a PC any day). He'd mostly be using it for school projects and his music.
Possible relevant side notes: I have a Macbook (2006) that I just replaced a failed hard drive in and upgraded the OS and memory. Reinstalled the iLife '06 suite and it runs GREAT.
So my questions are -
1. Can the upgrades described above be done
2. Is it worth it
3. Would I be able to install the iLife suite that came with my Macbook on the iMac also?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
This system can run Mac OS X 10.6 "Snow Leopard". However, it cannot boot in 64-bit mode nor does it support "OpenCL". It cannot run versions of Mac OS X more recent than 10.6.8.
If this answer is acceptable please remember to return and mark it.
Был ли этот ответ полезен?
Оценка 3
4 Комментариев:
Thanks machead3 for your reply. As a follow up, what might be my options for making this a decent functioning iMac? I'm not a techie so I lost you on the 64-bit OpenCL part. Could you clarify? Thanks!
из
The OS will install as a crippled version - some of it will work. It depends on what you intend to do with the machine. E-mail and web-shopping will be fine, some graphic intensive and game apps will not work.
из
What if you swap over the CPU to a Core 2 Duo? Will later 64-bit OSX's install? Thanks!
из
Not really possible, Sorry ;-{
из
Добавьте свой ответ
JP будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 210
