The Memorex 2Xtreme MP3830-01 is a fully featured CD stereo boombox complete with AM/FM radio.
4вопросов Показать все
Front LCD display no longer works
The device is able to power on and play music but no numbers or other information can be seen on the LCD display.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
A possible fix could be as simple as turning the unit off and on again. To ensure that the device is fully powered off, remove any batteries from it before turning it back on. If the LCD screen still does not display information, the LCD display has most likely died. Fixing the device would involve a more complicated repair: replacing the LCD display. However, this is possible if you follow our guide on replacing the display.
Был ли этот ответ полезен?
Оценка 3
Just go for replacement,its a factory Error,cheers mate.
Оценка 1
Добавьте свой ответ
Meghan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 245
