A lawn mower made by the American Company Toro
119вопросов Показать все
White smoke and spitting oil?
I shouldn't be allowed to operate power tools anymore, but whatever... I was mowing my yard when I hit a piece of hidden wood. A piece of wood jammed against the side of the lawnmower and the blade, which required me to flip it on its side and dislodge the chunk of wood. After I removed the wood, I put the mower back into its right position and took a break (It's hot out..). After my 45-minute break, I went to start it to finish cutting and it was belching out white smoke, and leaking and spitting oil out of the muffler. My father and I took a look at it finding nothing, but I took off the air filter cover and there was also an oily residue in there, more than normal. What could be wrong with it?
P.S: Comment if you want pictures.
Это хороший вопрос?
Оценка 17
8 Комментариев
oh, the engine is a Briggs and Stratton
из
I had a whole tank of gas drain out of my timemaster while sitting in the garage for 2 days. I added gas and it barely started, then cut off after 20 seconds. It started a few other times for a short period, then blew out white smoke and drips of oil from the exhaust. What could be the problem here?
из
I have a craftsman Lt 1000 with a 16.5 hp briggs and stratton engine. I adjusted the valves and now the engine is smoking (white smoke) and blowing a little oil out of the exhaust.
из
Carburetor shut off not working. Drain the oil, pull the spark plug and let the gas evaporate. Put an inline shutoff on the gas line
из
I bought used craftsman LT 1000. Fixed carb and adjusted valves adjust ignition coil but when inStarted it , it started to smoke blueish and whitish smoke out of exhast burning oil. I thought valve seals but i opened air cleaner cover and saw oil in the air duct housing of carb i started again and saw that oil is being pushed out of pvc breather , crankcase breather . Its just at the top of carb under the flywheel housing. The pressure its spraying with is like a high pressure tap . I pulled off the rubber pipe from both sides carb and engine side and see oul layong in that long path. What causes that and what is a the quick or proper fix for it. If i routed that cranckcase breather pipe back to shoot back in engine oil housing oil pan side from dipstick or from oul drain plug side Will that cause some major problems? Also is it normal for the engine to blow outwards the oil if dipstic is pulled from the engine? I never had riding mower before never worked on them but i was an auto mechanic.
из
Показать 3 больше комментариев
Добавить комментарий
9 Ответов
Выбранное решение
Skippy, when you flipped it over, you drained engine oil into the cylinder. If you let it run long enough, the oil will burn itself off.
Or, you can remove the muffler, drip the excess oil out of the engine, clean it up a little with WD-40 and a rag, reassemble it, and start it up again.
It may be a good idea to remove the spark plug and either clean or replace it. If you can clean the air filter, do that also—or replace it with a new one.
Good luck. Let us know how it goes.
Frank
Был ли этот ответ полезен?
Оценка 24
21 Комментариев:
+ Ralph
из
Thanks dude, it's not spitting oil anymore and no more smoke
из
Cool. Next time you have to tip it up again, put the carb side in the air and you will avoid the smoking again.
из
Uumm, do you mean the muffler side? I had the carb side up in the air when I did this (the muffler was pointed down towards the ground).
из
I have a Honda lawnmower and the muffler for some reason cannot come off and plus how can I take the oil out of the engine when its full...Secondly my other lawnmower I have has a cord to start the engine came out...how can i fix it...
из
Показать 16 больше комментариев
Im suprised noone said that you arent supposed to tip a lawn mower on its side, Your supposed to tip it front end up..
Оценка 9
3 Комментариев:
Ok so same thing has happened to me. Brand new mower, used only for 2 Yrs. white smoke is coming out of it big time!!! Now it doesn't want to start.
из
If it's 2 years old, it was brand new 2 years ago. Now it's 2 years old, which is quite far from brand new.
из
He mean to say that it is only 2 years old since he bought. Though a lawn mower may not last a life time it should definitely last more than 2 years. The issue is that the lawn mower may have tilted while you were mowing and too much oil may have come out to the filter. Open the filter and clean it up or replace it and also replace the spark plug and you should be good to go.
из
I have oil pumping out of the crankcase vent tube into the carb which makes a big plume of smoke. I had tipped the engine over to get the oil out to change it.
Оценка 4
3 Комментариев:
The answer from 040304 should work for you as well.
из
I bought a use mower from a guy and the mower did not have but a little oil in it. I put oil in it and started the mower and the mower started blowing white smoke and I have oil pouring out of the mower, can anyone tell me what just happen. What do I need to do to stop the oil leak and the smoke.
из
The oil is leaking by rings on piston or you added to much oil.
из
I have been noticing puffs of white smoke and obvious distress of the power of the Briggs and Stratton on my Toro engine as the oil is sucked into the engine on a bend or slope, it lasts for a couple of seconds and clears up. I did a check on the oil level and found it to be too high. Odd that, as it was okay in the summer. Just tried again today (the grass needs a cut despite being January) after not using the mower for a couple of months ( did not drain out the fuel for the winter) and could not start the thing. Huge puffs of white oil filled smoke from the exhaust, but not quite starting. Checked the oil and found it was no longer oil but mostly petrol / oil mix and way too full. Drained out the oil and replaced it and ride on mower started first time with oodles of white smoke burning off for a while. Trip round the garden and all well as far as the engine is concerned. Just need to solve how petrol can transfer directly into the oil sump. There is no stop $!^& on the fuel side so perhaps the float valve has stuck open and petrol has been dripping into the engine and passing the rings. Any ideas?
Оценка 1
8 Комментариев:
All well with the engine. A new float valve assembly in the carb and seems to have cured the fuel leak. The fuel does go down into the crankcase ( weird design issue) when the float seal fails with wear. Added a stopper on the fuel line as well to be extra certain. New head gasket and cleaned out the very carboned head and piston top and replaced the spark plug. Set the tappets and all runs sweetly now.
из
I had my lawn mower tipped forward in my shed over the winter an when I got it out to cut grass for the first time this year it started spitting out oil and white smoke is it gonna blow up on me I'm scared to use it and I don't no what the thing is called that it spitted the oil out of its on the side of lawnmower with a bunch of little tiny holes in it plz help
из
And Does a lawnmower take the same kinda oil a car does
из
the kind of oil you need should be in your owners manual and the type of oil needed is based on the outside temperature.
из
It is possible that you have oil pouring in if you have tilted your lawnmower... But the other cause if you have not tilted it and it is getting out into the carb is that you have a clogged oil return port inside the engine. The way the engine works is there is a filter over the valves that is supposed to let exhuast gas vent from the engine back into the carb... There is also a lot of oil inside the engine stirred up everywhere and a valve and filter assembly that is supposed to allow the exhaust gas out of the engine into the carb but keep the oil from escaping. It works by having a filter that is supposed to catch the oil that will then run down via gravity to the bottom of the valve filter assembly. There is a small hole at the bottom where the oil is intended to drain back into where it makes its way back to the bottom of the engine block.
из
My 1987 Toro has an oil soaked sponge-type breather, and there's a tube from there to the crank case, presumably to vent it with clean air. Unfortunately, when I tip her front wheels high (which puts the breather, carb and spark plug up in the air - they're all at the front), oil runs into that tube. Then when I set her back down, the oil continues its journey into the breather and straight into the carb. The wonders of gravity! This must be why my manual says to drain the gas and oil before changing the blade. I've recently added a fuel shut-off, so that helps a little...
Оценка 1
1 Комментарий:
I don't think provision placement was as important back in the day as it is today. It is indeed a breather tube to vent positive pressure from the crankcase out to the atmosphere. Too much positive pressure in the crankcase does all kinds of weird things (It will even compromise the ability of your piston rings to do their job, resulting in compromised compression as well as oil blow-by (which would cause smoking when in an operating position)
Definitely drain your oil before any severe tilts. You could also plug off the breather tube as an alternative , but the oil will still fill the breather tube while the mower is tilted. You'll just prevent it from going past a certain point.
из
same thing just happened to me, hit a rock and lawn mower died out, now the round thing that blows out the smoke is spitting out oil when i go to start it everytime, occasionally i can get it started again but it wants to die out and will eventually die out, after a few mins
Оценка 0
2 Комментариев:
If your blade hit a big/heavy rock and stalled it is possible that you have a bend crank.
из
Mine made me mad I hit a big high patch of grass and it was just a huge rock under there mine starts and runs for about 30 seconds but it puffs the white smoke and oil runs out every where but it doesn't get any lower on oil I'm up to the full line
из
DUDES!!!!!!thanks it worked. First my lawn mower didn't start had gas gap open ,tipped it a little then I I started lawn mower , muffler spitting oil, filter dirty with oil. Took muffler off cleaned with w 40 first,filled with windex shaked cleaned then I water hosed down until no foam was form.but it together and then start it on again. A little smoke came out waited a lil and no smoke came out at all .tomorrow. Buying new spark plug,filter and see what happens. Everything works but tomorrow I'm cutting my lawn so let see what happens .THANKS. Everybody
Оценка 0
1 Комментарий:
I have a 25 hp kohler engine .it guitar on me while I was mowing an doesn't want to crank.it has been about a week
I tried to crank it today an it crank but it was discharging white smoke an oil out the muffler an the oil stick .what would be the problem.
из
my toro lawn mower started smoking and quit. it looked like black smoke. there's oil in it. at first it sound like it was going to cut off. I kept mowing till it finally quit. what do you think is wrong
Оценка 0
2 Комментариев:
my troy lawn mower was put away, when i went to use it the oil cap was blown off i guess from the heat in the shed its strats up with out problem but leaking oil and white smoke please help
из
K.
In November 2016 I was just finishing mulching up leaves when the mower starting making a noise like a metal pully/wheel spinning on a metal axel. Immediately let go of handle. Pulled rope to restart. The rope did not recoil. Took mower to shop I purchased it at just the other day. They called today to say the motor did not have any oil! I just purchased this mower this summer. I always checked the oil. As a matter of a fact it was the the sow room modle. The store put oil in it when I bought it. Shortly after that I wanted to mow. The mower would not start. Took it back to the shop. They said there was oil in the filter. This mower sat flat in a storage barn/she'd when not in use. I had no problems until until November. Thought I would get it tuned up for Spring. What's the deal T O R O?
из
I have a power washer that tipped forward during travel and the pull string would not pull. I took out the spark plug and pulled it to remove the oil but when it runs it will not hold pressure and smokes. I have changed the spark plug 4 times so I assume i need to clean oil out of it in another area.
Any advice?
Thanks
Оценка 0
Добавьте свой ответ
Skippy722 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 105
За последние 7 дней: 697
За последние 30 дней: 2,632
За всё время: 490,181
