Repair guides and troubleshooting for the Acer Aspire V5, a series of laptops on the Windows OS by Acer.
132вопросов Показать все
It turns on, and that's it :-(
My computer is a Acer Aspire v5, with windows 8. It will only light up a black screen where I can move my mouse across without lags, but this is how far it comes, the Acer logo appeard the first time I turned it on but after I shut it down with the on/off button it just shows me the black screen with the possibility to move the mouse.
Это хороший вопрос?
Оценка 1
1 Комментарий:
I have spammed the F8 button and alt+ F10 at start up, nothing happend.
из
Добавить комментарий
4 Ответов
Just wanted to confirm a few things..
Did you do a hard power down by holding the power button down for 5 seconds or by just briefly pressing the power button (which would put the computer to Sleep).
I've found this laptop occasionally does not properly recover from Sleeping under Win8, that's why I ask.
Either way, do a hard power down by holding the power button for 5 seconds.
Unplug the laptop and find the battery disconnect pinhole switch underneath (indicated with a picture of a battery lifted up) and using a paperclip press and hold for 30 seconds.
Try powering on again, do you atleast get the Acer logo appearing when powering on?
Let's start from there..
Был ли этот ответ полезен?
Оценка 0
I am having this same problem. I took off the case and pulled the battery to reset the CMOS. That didn't work. The backlit keyboard comes on but that's all. Black when I try to power on. I pulled out the battery and left it out for 5 minutes. Put it back in and nothing. Changed power supply. Nothing. changed outlets. Nothing.
Оценка 0
1 Комментарий:
Did you ever get yours to turn on?
из
My laptop just shows "Acer exploring beyond limits" that's it doesn't go further than that
Оценка 0
1 Комментарий:
@upulasi_st3v3 Try removing the battery disconnecting the power adapter and holding the power button down for 60 seconds then reinstall the battery and plug in the power adapter then boot the computer. Hope this helps
из
@upulasi_st3v3 @dmsosb (and bbspige too, but I can't figure out how to @ him\her): How long have you waited for without it starting up?
Just asking because Aspire V5s, especially older ones, can sometimes take an extremely long time to turn on (my three-year-old V5-122P sometimes takes several minutes to start up), so, if you were waiting only a minute or so and then powered it back down, it's possible (although by no means certain or even probable) that it would have eventually started fully.
Оценка 0
Добавьте свой ответ
bbspige будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 9
За всё время: 2,294
