Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
1233вопросов Показать все
Why isn't my iPhone working properly?
There are a bunch of things wrong with my iPhone. I cannot lock it without working. It won't let me unlock the lock screen. It won't let me text and I have rebooted it several times. I went to my phone company and called apple.
Это хороший вопрос?
Оценка -1
1 Комментарий:
You might want to clarify your exact problem and tell us a little bit of the history of the device---drops, prior repair, water etc.
из
Добавить комментарий
1 ответ
The 5C's rear housing design is plastic as we known. This means it flexes when dropped or bumped. This causes the screen's "tabs" at the top to loosen thus breaking ribbons or destroying the circuits (ESD, Liquid, etc). The plugs controlling all of these functions lye at the top right corner of the back of the screen.
If the top of the screen is protruding then take it straight to Apple for a replacement. If the glass cracks they won't cover it. If the don't we can always help or you can learn and buy parts right here on iFixit.
If you happened to open it up and the screen isn't connected the other half then the ribbons are broken. You'll need a new screen and front camera to fix the issue.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
[image|427284]
To the left of the red box (the A6) is actually the top of the board. So this is where the touchscreen, front camera, and power ribbon attach. If you open it this is what you're looking for.
из
Добавьте свой ответ
Bailey Bristol будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,092
