The LG Optimus L7 P705 has a 4.3 inch LCD screen and weighs 4.3 ounces. It has a 5 megapixel camera and a LED flash. It houses 4 GB of internal memory with a SD slot that holds up to 32 GB of memory.
Why won't my device respond to commands if it is on?
My device is on, but it refuses to respond to any command. It seems frozen.
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
1. Try to lock and unlock device (Soft Reset). If problem persists, turn device off, wait a few seconds, then turn back on. If soft reset does not work, see guide for Replacing Home Button. Once device is working again, close all applications and websites that may be too intense for device.
2. Touchscreen is not working. Verify that protective cover, or case, is not interfering with touchscreen sensitivity. Perform a soft reset. Identify if operating system is affecting touchscreen functionality. Verify that there are no cracks on the display. If there are cracks on the display, see guide for Replacing the Display.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Bruna буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 219
