10.1" Android tablet released in June of 2011. Samsung GT-P7510MA
Вопросов 20 Показать все
Why is my tablet not charging?
Couple weeks ago my galaxy tab 10.1's power is 1%, then i shut it down. After that i charged my tab and left it a couple of minutes, but when i see the charging bar it dosent gain power. it keeps going back n fort for hours but still it didnt fill up to the middle. After that this happend link:http://www.youtube.com/watch?v=2fW48hGB7...
But i solved it by pressing hold the power button in 1 min(30 sec, plug in charger,30sec release power button.)
you can see that procedure on the video's comments.
P.S
pls find a way because im so desperate. I cant afford to fix or buy another battery. My parents are strict
Это хороший вопрос?
Оценка 15
11 Комментариев
But still it dosent charge. It goes back n fort but not in that video
из
Ty this worked perfectly :)
из
Worked! Went from no charging to charging.
из
This actually works!!!! Thanks a million!!!!
из
Holy $@$*! It worked! I'll be damned! Thank you!!!!!
из
Показать 6 больше комментариев
Добавить комментарий
Ответов (14)
Наиболее полезный ответ
Blow into the charger port that worked for me
Был ли этот ответ полезен?
Оценка 5
9 Комментариев:
It worked for me too!! Thanks for the tip!
из
Lol this stupid why didn't i try this before xD
из
Far out it worked for me too....i laughed and felt stupid doing it but its amazing. Some people i know might get some life into them if i blow into their ears....worth trying!
из
I thought this was stupid, but I gave this a try and it works. I feel dumb that I didn't think of that, but hey, it works! Try this out.
из
Sometimes there is lint inside. A super fine toothpick or something can get it out. Just aim for the lint and not the gold pins cause you can damage them.
из
Показать 4 больше комментариев
Why not just order a new charge port and replace it? Just got one fixed at the store I work at. Her tablet charges fine now!
Оценка 2
1 Комментарий:
It's a super easy repair. Hardest part is removing outer shell. Once inside. Super easy.
из
My samsung tab 3 is not charging when it is turn on i have originol charger plessss helppppp me
Оценка 1
1 Комментарий:
Or instead of hijacking peoples post, and preventing them from getting answers they need, you could start your own forum. @%^$^@.
из
With my Galaxy Tab 10.1 I was able to resolve this issue by removing the back cover and disconnecting the battery for 60 sec, then reconnecting it. After doing so the tablet charged as normal.
Оценка 1
My tablet in not charging it was off for same months now plz help me to turn it on
Оценка 0
My tablet screen is black. I can't tell if it's charging and I don' really have a computer to plug it into, I know the cord is all good, plug good... Did the volume button trick, nothing. Took the back off but very leary of taking the battery out, looks like it's taped in. Galaxy tab pro 10.1
Оценка 0
4 Комментариев:
Anyone there? How long will it take to generate the answer on how to safely remove the battery
из
I don't know about the pro. But use tweezers to GENTLY peel back the tape starting at a corner. It shouldn't be too hard to remove and I bet the battery is screwed in place. Also try searching the site for a tear down that might help you see how the battery comes out. Or search your model number along with "battery removal" using your favorite search engine.
из
"generate the answer"? I thought iFixit was a portal to people who like to fix things and also share the knowledge and experiences voluntarily, - not a maintenance/consultant service working 24/7 to solve everthing for free...
из
His English isn't the best there lol. I don't get what you mean though about the maintenance/consultant service comment..
из
Was not working for me after changing a new charging port, but it work normal with it's original adapter and cable. Just try to use original charger to get rid of it.
Thanks
Оценка 0
I have no idea if this is the correct place to ask a question but I'm at my wits end.. A few weeks ago my tablet fell below 10% for the first time in the 2yrs iv had my Samsung tab4 10.1 and it cut off completely so I done the suggested soft reset..
things were fine for a week until my tablet sent the 'low batt' msg while plugged in.. it was then I saw the big red cross through the battery sign..
I have soft reset
updated software
hard reset
replaced battery
tried new cable
old cable
new and old sub plug
and whole unit plug
into wall and extension
and new charging port and battery with expensive genuine Samsung replacements.. prayed to the heavens I would turn it on and all would be ok.. but... NO! exactly the same!! there isn't anything on my tablet it's used to watch my programmes on show box etc.. please some one help! any advice I'd be grateful for..
kindest regsrds
Оценка 0
Mine was doing the same so I grabbed a thin knife and pushed the usb port in to make it more secure then plugged it into my computer went back a few hours later so turned it on and wow its up to 65% and its charging still hope this helps you it worked for me a few seconds and its working
Оценка 0
1 Комментарий:
Wish I could send a photo its up to 87% wow
из
Just push the usb charging port together to tighten the port where the usb goes in but be gentle then plug it into your pc and leave it for a hour or so go back to it turn it on and it will be charging mines nearly fully charged it works awesome I did this for my galaxy s6 because the charging port was loose and it worked fine so I did the same procedure to my tablet hope this works for you as it worked for me
Оценка 0
Cleaning charge hole on tablet or scraping charge pins of the cable is one way to get the charge working. However the issue is that adaptors do have life. When the original adaptor goes bad, it drains the note while on charge ! To test this out, use a USB cable to charge the mobile using a laptop. It would take a while but will reach 100%.
Solution is to get a new adaptor. But then you can also get a new cable because through travel and use it will also go bad too.
Anil
Оценка 0
Holding the power button and then plugging in worked… weird
Оценка 0
It worked for me too! :D
Оценка 0
So with all the Chargers I have my tablet doesn't charge I don't know if it's my tablet that has a problem that doesn't let the Chargers charge Sprint desperate I need a charger that works right now because most of the time I don't let my tablet go below 80 and it's gone below 80 and I'm losing my mind???????????
Оценка 0
1 Комментарий:
There's a typo in there sorry
из
Добавьте свой ответ
Brian будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 26
За последние 30 дней: 106
За всё время: 107,131
