Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
Overcharge protection. Function of battery or phone?
I need to charge my battery externally. My only concern is overcharging and ruining the battery. I know there is a circuit somewhere that prevents overcharging. Is that circuit built into the battery, or is it part of the phones hardware?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Its in both!
The sensors are within the battery and the controlling logic is within the phone. Li-Ion batteries need to be charged with a special charger you can't just plug any power source to the battery.
Here's a basic writeup on what needs to be done: Charging Lithium-ion. As you can see its a bit of work. Here's a sample circuit: Make this Li-Ion Battery Charger Circuit. The only problem here is you would need to dig a bit deeper to find out if this would work for a iPhone 4s battery, I'm not sure it would.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jesse будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 993
