8 beeps with full black screen
i have tried few ideas :
1. remove battery & power plug then push power button for 1 min.
2. remove ram and insert it again
3. press D+Power button
4. fn+ Power button.
but none of this work...
have you any idea accept this...??
what is the reason for this 8 beep & black screen??
Update
i tried that option with HDMI cable Fn+F1 keys to us the external monitor. .. but it still beeps 8 time... and i think its not detecting HDMI... what should i do..?
Это хороший вопрос?
2 Комментариев
after lot time switch on off... finally it started once and thn i restore BIOS settings and format d oprating system... thn check in diagnostics test... but everything is alright... but still my problm is not solved after few hours it as usual started 8 beeps and black screen when i switch it on... i could not caught the problem...
из apurvajimmy777
I have the same problem but when I use the external monitor the laptops works fine. I tested the LCD screen with a different laptop and the screen works fine. so what could be the cause of the beeping and black screen?
из Samuel Motsamai
