Repair guides and support for all types of batteries.
74вопросов Показать все
Risks of short-circuiting Li-ion battery?
I received a new Haier Li-ion battery (haier h11255) for my cell phone and although it seems identical to the old one, it does not work. After some tinkering I discovered that the 4 'pins' on the battery are in another order then they should be. I can easily fix this by connecting two of the pins, which I tried using a paperclip. Is there any risk doing this? If so, what are they?
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
Definitely get rid of that battery. One of the four pins is used to measure BTemp (battery temp.). When it's temp. is beyond a specified range, the battery will stop charging to prevent overheating. Unordered pins are a bad sign.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
Return the battery and get the correct one. Don't chance it!
The battery can explode or catch on fire if sorted.
Оценка 1
Добавьте свой ответ
Tom будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 517
