Cen-Tech Seven Function Digital Multimeter . Model number 90899.
Why won't the screen show any readout?
I want to use my multimeter to test a battery. The banana plugs are attached and cords are attached to the device, but the screen is not reading anything. My device is turned on and seems to be functioning otherwise.
Это хороший вопрос?
Счет -1
Добавить комментарий
2 Ответов
The reading screen is either broken or malfunctioning. You may need to replace the screen. See screen replacement guide here. If this does not seem to fix the problem, you may have an issue with the motherboard. Click here to see how to replace the motherboard.
Cen-Tech Seven Function Digital Multimeter Mainboard Изображение
Инструкция
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Сложность:
Легко
5 - 15 minutes
Cen-Tech Seven Function Digital Multimeter Screen Изображение
Инструкция
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Сложность:
Легко
10 - 15 minutes
Был ли этот ответ полезен?
Счет 0
I'm all for fixing stuff and keeping it working, but Harbor Freight literally gives these meters away. They're not worth fixing. i have a stack of spare ones still in the package waiting to be used.
Счет 0
Добавьте свой ответ
Anna Kihm буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,810
