Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
iPhone 5 screen not fitting/slotting into the housing/fascia.
Hello,
I've moved all the components of a damaged iPhone 5 into a new housing and it all works great. However I cannot seem to slot in or place the iPhone 5 screen into position.
The bottom part and sides of the iPhone 5 screen fits in no problem, however the top part of the screen does not fit into the housing. I unfortunately eventually applied enough pressure to crack the screen. It still turns and works great; only the top has a minor crack, no damage to the LCD or digitiser.
I'm going to replace it with a new screen, but what should I do to avoid this from occurring next time? Even with the amount of pressure I applied it didn't move down any further.
Thank you very much. :)
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
Look at the screen at the top there is 3 plastic brackets and these need installed under the frame .. Top of the screen needs fitted at about a 30degree angle you will see the screen at the top line up flush with the frame.. Now the bottom of the screen will be slightly raised put pressure on it upwards as if you pushing the screen flusher against the frame.. Then push down the entire left side and the bottom left should pop in then the other side with slot in no problem.. Hope that makes sense
Был ли этот ответ полезен?
Оценка 4
2 Комментариев:
Thank you very much! I didn't realise that, I tried it again and it fit in perfect. Unfortunately however I had already cracked the screen, so I'll ensure I insert the top part of the screen first next time. For others with the same issue, holding your screen at a 30 degrees angle (bottom part being the top of the screen), insert this into your housing (it's below the housing's bevel/frame); then push in the slides and eventually the bottom. I hope it works out for all of you! :D
из
hey. i got the same problem, the top is some mm over the frame. but what do you mean 3 plastic brackets con? how do i install 3 brackets under frame? where are the brackets??
из
Glad this worked for you friend :)
Оценка 1
Does the metal frame look dented in any corners
Оценка 0
1 Комментарий:
Fortunately no, they're all perfectly straight and curved on corners. Here's a picture of the housing before inserting all the components: http://imgur.com/xHwp9XU The housing is for the iPhone 5 and it's a Space Grey/5S-like colour.
Thank you very much for your reply though. :)
из
Добавьте свой ответ
Arif Ullah будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 4,575
