Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
Вопрос закрыт
iPhone 4: Black Screen and "bong" Tone/Noise
I tried to follow the tutorial to repair my iPhone 4's home button. Unfortunately the process was a failure because I am now experiencing a black screen and a never ending "bong" noise when plugged into a wall outlet.
Can anyone help/provide insight as to what's happened to it and if you think I can fix this, or should I just junk it for parts/repair on ebay? I don't know if this means the logic board has failed...
https://www.youtube.com/watch?v=BR9B-Fye...
Edit: I gave up. I took the whole thing apart and and tried to reassemble and the same thing occurrs. Not worth fixing this phone ($40 for a display really?) so I will be putting it on ebay for parts or repair.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Open back up and make sure the screen connecrors are fully pressed down and seeded correctly if still the same after that you will need to try a new screen.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thanks for your response. They are definitely seated correctly - I've reseated them a few times now trying to resolve this (probably only making my chances of getting this to work even worse). So do you think that I destroyed the LCD screen cable? I was pretty careful while I did it and there is no visible damage ie like a cut or hanging cable, so I'm pretty disappointed...
из
Try to do a hard reset on the phone... holding home button and power button at the same time.
Оценка 0
1 Комментарий:
Didn't work, unfortunately.
из
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 302
