Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
What can cause a blank black screen on iPhone 5S?
I am trying to repair an iPhone 5S. I have tested its LCD, and it is working perfectly. I connected the phone to a laptop, and iTunes just responds correctly as if it is a normal iPhone, displaying its information, contents in memory, etc. But there is nothing on the iPhone screen. I wonder if there is anything other than the logic board that can cause zero video output to the LCD.
Это хороший вопрос?
Оценка 10
1 Комментарий
Got an old phone from a friend that does for me ( I'm hardly a tech head
из
Добавить комментарий
14 Ответов
Наиболее полезный ответ
Press and hold down the Sleep/Wake button and the Home button simultaneously for at least 10 seconds. The screen will clear out and then the Apple Logo will appear on the black background. When the logo appears it means that the reset is done.
Был ли этот ответ полезен?
Оценка 12
6 Комментариев:
well done! thanks!
из
Thanks! It really helps
из
what if your home button doesnt work
из
Thanks Vanilaleean for a concise clear explanation. Fixed a scary problem.
из
3times fastclick home button,backlight will turn on...try it.
из
Показать 1 больше комментариев
Do you have the old screen to test the phone with? If so try that and if that displays correctly then it's the screen it self
Оценка 0
7 Комментариев:
Try to reseat the connector if everything works
из
And do a hard reset.. Holding power button and home button
из
I have four different working screens to test with and none is showing anything. I also tried using a working logic board from another phone, and nothing shows up on the screen either.
из
Just done a full re-assembly and problem solved. still not sure about what went wrong though.
из
My sons iPhone 5s droned totally of power and even after being plugged in all day trying different iPhone chargers! It gives us the apple then goes to a black blank screen like it is on but nothing on the screen! I have tried several times to hold down home button and power button and it does it all over again with same results! Any help appreciated!
из
Показать 2 больше комментариев
This makes no sense at all screens work but not with 5c change logic board and still don't work now they don't?? Confused
Оценка 0
I have same problem however, i cannot turn off phone. I can use voice commands but nothing screen related. this after i dropped my phone and ended up with vertical lines turning into eventual purple screen. I tried reseating connectors. now have black screen. Any suggestions?
Оценка 0
i too have the same problem and I have tried every steps but nothing has worked. please help me out
Оценка 0
Why wont it let you turn it on when the I tunes logo pops up?
Оценка 0
1 Комментарий:
3times fastclick home button...try backlight lite.
из
Thanks a lot! It really helps
Оценка 0
why did my iphone screen got darker as i pressed the power button
Оценка 0
try reseating the screen connector
Оценка 0
My iPhone 5s is not turning on
Оценка 0
My iPhone 5s won't turning on
Оценка 0
What makes an iPhone to show black screen? Here are some reasons.
  • An issue with the logic boards and causes black screen.
  • Issues with screen orientation.
  • Physical fault in the device.
  • Caused by some third-party apps.
If it’s not a hardware issue, you can simply fix the black screen problem without data loss with the help of Fixppo.
Оценка 0
1st Solution - Restart Your Phone… 2nd Solution- Setting > general > accessebility > And Turn Over The Voice- over feature…?
Оценка 0
Can you see any sort of liquid damage on the logic board? A minor liquid can damage the conductors and transmitters.
Оценка 0
Добавьте свой ответ
jjackzhn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 51,578
