This is a guide for the LG Optimus G Pro Phone. It was released February 2013, and can easily be identified by its Model Number: E980.
Why is by front camera not working?
My front camera refuse to work. Every time itry lunching it, it freeze for a minute and says" camera unexpectedly stop, restart " even apps like snapchat don't work. But the back camera is working greay. Why might be the reason and how can I fix it?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi rStephen,
It may be due to a software glitch, but most likely it is going to be a hardware issue. I say most likely because it is usually never as easy as resetting your device. The front camera can be found pretty inexpensively, so you can test this fix for most likely under $10. If all else fails, factory reset might help. Good luck!
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
rStephen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 1,537
