Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376вопросов Показать все
Loud audible spinning and vibration, top left corner
So my late 2008 Unibody MacBook Pro starts vibrating/spinning loudly in the top left corner region. Checked the temp/fan speed/processes, and they seemed pretty normal to me. It's not definitely not the normal fan spinning up kind of feel, it seems pretty abnormal. Anyone know what might be the issue? GPU? CPU?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Here's how to replace the left fan: MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement
Here's the part you need: MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Left Fan
Был ли этот ответ полезен?
Оценка 4
The left fan of my MacBook Pro 15" Unibody Late 2008 was noisy and I wanted to replace it. I purchased a replacement fan from ifixit and used their manual. All was fine, but the manual / description does not tell you what to do if the 3.5 mm screws (Phillips00) have frozen / ceased. I contacted ifixit who suggested using a rubberband over the tip of the phillips00 screwdriver. That worked even though I had slightly stripped the screw head during previous tries. However, I could not remove a third screw using the rubberband technique nor using superglue to fix the screwdriver to the screw head. So I purchased the MicroGrabbit, #1257P, a screw extractor from Aldn.com. Cost $8.99 at a local hardware store. The technical support at aldn.com was helpful as well. The screw came out very easily. In short, when all else fails, this may be your viable solution to extracting difficult screws of small size. The website is www.aldn.com. I am just a happy customer and nobody asked me to write this. I'm providing it as a helpful hint. Tom Simpson
Оценка 0
Добавьте свой ответ
fendy md будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 2,930
