The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526вопросов Показать все
Purple tint after removing the front glass
Hello, I tried this guide: Samsung Galaxy S4 Cracked Front Glass Replacement
To replace my S4 glass.
I managed to remove the glass, but the screen had a different color in one zone. I was concerned about it, so I tried turning it on, and I found that it that area the screen is purple-ish.
What can I do about it? Do I have to buy the whole assembly to replace everything?
Touchscreen works even in that area, so I guess it's not the digitizer. Maybe something can be done software-wise to balance the wrong color?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi Cero,
Unfortunately, that looks to be some damage to the display caused during glass removal. Very few times does this go away over time and most often then not a new display assembly is required.
Был ли этот ответ полезен?
Оценка 3
Same issue here. Did you fix it? Was also told it's the "glue" used to replace screen glass and that it will go away eventually???
Оценка 0
2 Комментариев:
If it really was the glue, cleaning it off the screen should solve the issue then.
из
Yip, not the glue at all... they clearly damaged the display and the touch is unresponsive in places
из
Добавьте свой ответ
Cero будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 1,187
