The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114вопросов Показать все
Вопрос закрыт
Change digitizer ONLY on Xperia Z3?
Hi everyone, does anyone know if its possible to change the digitizer only on the Z3? or is it bonded like the samsungs? I have replace 100s of glass only on samsungs so if it is bonded then its no problem I just need to know so I can order the right part.
Thanks in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Pretty much all of them are bonded using LOCA now so you're good to go.
Also, I'm curious to know what tools you use for the samsung and your method of removing the LCD from the frame?
Был ли этот ответ полезен?
Оценка 0
see the picture below, they are bonded and it's difficult to separate,
Оценка 0
https://www.youtube.com/watch?v=levTY6Ix...
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 6,088
