Black Screen, Completely Dead already! PLEASE HELP!
This has happened to me three times now. Screen goes black and will not load up again for ages. Pressed the reset button far too many times already.(volume up n power off button) but still not workin
Это хороший вопрос?
Оценка 56
8 Комментариев
plzz someone help !!!
из
i have to wait a minute and it comes good
из
Omg the reset feature helped me thank you osooooo much
из
Worked for me too. Thank you!
из
hi reset has not worked for me, please help
из
Показать 3 больше комментариев
Добавить комментарий
3 Ответов
Наиболее полезный ответ
https://www.youtube.com/watch?v=DU2u0ISz...
This should help your issue.
Please accept this answer or score if it has helped
Был ли этот ответ полезен?
Оценка 5
8 Комментариев:
thanks it was solved
из
I tried. It doesn't work
из
@moiragabrielleh01 - what is the damage? did you drop the phone?
из
Just did this, like in the video it takes a few attempts but worked!
из
That is brilliant news @Cevaughan!
из
Hold both power and volume up for 10 seconds. My phone just got blankscreen over an hour today, just did it and successfully worked! Hope this helps
Оценка 1
1 Комментарий:
It wasn't work.... I need help for the sony xperia e3 all of the videos on youtube wasn't work
из
i had such a problem too, my phone was flashed by some technician, but problem persisted. so i opted to change d battery and its perfectly working a gain....
Оценка 0
1 Комментарий:
cange your baterai, i have that experience too
из
Добавьте свой ответ
priyanka будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 93,338
