The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
82вопросов Показать все
How to Fix the Buttons on an original DS?
I replaced the shell on my ds system, All the buttons worked fine before but now most of the buttons are responsive! I've tried reopening it and fiddling with the rubber under them but to no avail! Any Help is greatly appreciated.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
you wrote "the buttons are responive" - did you mean unresponsive?
did you use an original nintendo case or one of those "original nintendo" cases from ebay ?
the problem could be to much pressure on one or more buttons, that way they act like they are always pressed and that way no button would work.
i would start the ds with the open shell and see if the buttons work or not
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Jared будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 1,759
