A collection of repairs for on-ear, over-ear and in-ear headphones, earphones and earbuds.
2560вопросов Показать все
Headset Charging port not working on Beat Studio Wireless 2.0?
Charging port (micro usb) on the headset itself is not working properly.
When i plug it in, the power light turns on and off after a few seconds. Usually when you plug it, the power light blinks. I found out it is dodgy because when i plug and pull it on a certain angle, it charges, but then if i let it go, it stops.
is there a way to fix this? or any replacement parts like a replacement charging port. Is there a tutorial on how to open the headset?
Это хороший вопрос?
Оценка 9
Добавить комментарий
10 Ответов
Наиболее полезный ответ
There is a shop called Cyberion in Arundel mills mall that offered to look into it and repair it. They Said it's common in this headset offered to repair it for a reasonable cost. They replaced the micro USB port and everything was in working order after the repair.
Был ли этот ответ полезен?
Оценка 3
5 Комментариев:
What's the cost?
из
Could you tell me what kind of shop replaced this port for you? I'm having the same problem and don't know where to turn to. Thanks!
из
MyCyberion.com
из
JoesGE has repaired thousands of these headphones with the charger port issue. We sell the part for $35 https://bit.ly/2wbJtil and do the entire service for $70. https://bit.ly/2IZMI59.
Free shipping both ways if you want to send your Beats to our repair center.
из
How do u fix it
из
I found that this problem is not limited to the wire itself.. If it related to the actual port on the headphones becoming loose (wobbly) so movingit left or right makes it make contacts or makes it loose contact. I have tried several wires besides the ones that came wit the beats all with the same result. The problem is the little tiny piece of plastic that the metal pins are set against in the mico USB port on all of the Wireless Studio Beats. It isn't sturdy enough and eventually becomes loose... And for this much money that shuoldn't be happening... The metal pins I am talking about are what is needed to make contact with the pins in the micro usb plug tip on all cables.
Оценка 1
2 Комментариев:
Did you eventually get this problem solved? I am having the same issue with my headphones too. It is definitely not the charger cable that isn't the problem, it's the actual port on the headphones :/
из
If you still need the part or repair feel free to contact our support team. We fix the issue for $70 and sell the part for $35. support@joesge.com. Service: https://bit.ly/2wbJtil. Part: https://bit.ly/2wbJtil.
из
We sell this [ https://www.joesge.com/products/beats-st...|part] for $35 if you want to replace it yourself or if you want to send it in for repair we charge a flat rate of $65 for the entire service including shipping.
Оценка 1
I would get a replacement charger. This is just like phone chargers, the cable itself is most probably damaged.
take it to a repair shop and they should be able to have a look for you.
please accept this answer if it has helped.
Оценка 0
The answer, in my case, was the cord. One cord i have to anchor in a certain position for it to charge. Others, i just plug in and they work.
Оценка 0
Same issue here. Have tried multiple cords and unless I apply positive pressure on the cord towards the center of the device (pushing the connector itself outward from the center) it does not charge. So currently they are about worthless. Luckily I think I still have six months of warranty so they can fix it (this time).
Оценка 0
That happened to me, I taped them and they worked, but now I need to get the charging port fixed. I hope this helps, I am very sorry about your beats
Оценка 0
2 Комментариев:
what do you mean by taped them?
из
Did you end up getting a part? If you need one you can buy a port and the correct tape for the muff on our website. https://bit.ly/2wbJtil
из
It’s in Maryland. they can repair it for you via mail if you’re not from around the area. They specialize in computer and phone repairs so beats wireless was a walk in the park for them. W w w. MyCyberion.com is the website to book their Repair inquiries. I didn’t see a spot to select headset repair but I’m sure you can mention it in their “notes” section when you’re booking or inquiring.
Let me know if you need anything else!
Оценка 0
2 Комментариев:
Ok, the answer their techs gave me was that “wobbling it gives a temporary solution, but the permanent solution is to solder or replace the entire charging port. Cost for repair is worth it considering it’s a $200 to $350 set of headphones”.
из
We repair this issue for $70. Checkout our repair site for more details. https://www.joesge.com/pages/repair-serv...
из
Mine will not turn on at all
Оценка 0
1 Комментарий:
The best thing to do is to check your charger cable first. If the cable is good then the next step would be to check to see if the charger port is loose. If it wont turn on it could be a charger port issue, battery or power board. We fix all Beats related issues. Contact a Ninja for more help. support@joesge.com
из
can’t you pretty much use just about any old type of charger port from like a old obama phone technically ?? uhh, yes. &&^& paying $35.00 for dat $@$*
Оценка 0
Добавьте свой ответ
marlu tampus будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 40,176
