The economical version of the Samsung Galaxy S4, released in July 2013.
99вопросов Показать все
sim card not detected
I replaced the screen and digitizer on the phone and everything worked after i put it back together like the wifi and screen was good but it doesnt detect the sim card anymore. What are possible reasons for this happening and how can i fix it?
Это хороший вопрос?
Оценка 4
2 Комментариев
I have this same problem, but now that I've attached the new digitizer assembly I don't think I can remove it. Did you find a solution?
из
hi i have the same problem my samsung s4 mini wont read the sim card
i have clean the sim card the port too what else is there to do
please help me
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
As a first step, you may need to re-seat the connector cable of the SIM tray to the board.
If your are not sure which one it is, take the phone apart, examine every cable/connector on the board and/or just re-seat them all.
If you know which one it is, try also cleaning that connector with a cotton swab and 90%+ isopropyl alcohol (rubbing alcohol).
If the phone works with a different SIM (or as a precautionary step), clean the contact points of your original SIM card with an eraser or isopropyl alcohol. May be it collected something from your fingers during disassembly.
Был ли этот ответ полезен?
Оценка 1
I had the same problem as you after replacing the screen and digitizer. I took the phone apart again and did notice that the connector cable of the SIM card tray was loose as suggested in the previous answer. I had to slide it into/under the place it should connect to, in the photo below the small red box shows how the tray should connect, the tab of mine was out and I had to slide it under the brown thing, hope this helps!
http://www.etradesupply.com/blog/wp-cont...
Оценка 0
Добавьте свой ответ
mitchell будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 8,467
