Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61вопросов Показать все
will a ipad mini 2 lcd fit ipad mini 3
Hi
I run a small DIY screen replacement hobby business.
I have been caught out on this iPad Mini 3 A1599.
After checking suppliers they supplied me a digitizer with out the IC.
Also the digitizer they have listed comes with the standard "Home Button" of course Ipad mini 3 have "Finger Print reignition"
I have 1 question
#1 will the ipad mini 2 LCD fit and work on a ipad mini 3 ?
Thanks in advance
Darren
Это хороший вопрос?
Оценка 5
1 Комментарий
Thanks guys
I am having a heap of trouble trying to find parts for the ipad mini 3
suppliers are listing the ipad mini as having a standard hhome button (as far as im aware ALL ipad mini 3 can out with finger print touch
AAny help guys as to who selld ipad mini 3 parts ?
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Interestingly enough , I just received my first iPad Mini 3 LCD that I've ordered and it works without a problem. Screen Part # is LP079QX1-SP0V (LG)
If you do a Google search you'll see that LP079QX1-SP0V returns results for the iPad Mini 2 Genuine LCD , so I would say that yes the 2 LCD's are the same (at least in this case)
Был ли этот ответ полезен?
Оценка 4
the ipad min A1489 lcd is working in my ipad mini 3 A1599 ipad mini.
and the ipad min 3 works in the 2.
while i was working on the repairs i tried this out. works perfectly.
Оценка 2
Yup definitely different. I think it's the connectors. My supplier just told me they are different so I went by his word.
Оценка 1
No, the iPad mini 2 LCD cannot be worked on an iPad mini 3
Оценка 1
Добавьте свой ответ
Darren будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 33
За всё время: 8,741
