Part of Nokia's Lumia line of Windows smartphones. Announced July 2013.
35вопросов Показать все
proximity sensor not working aftet screen replacement
Just replaced a screen on a lumia 625. But the screen turns black when making calls. When I lift the screen away from the sensor, it shows again. Is there anything I can use whuch could strio the purple paint (or whatever it is) away from the glass where the proximity sensor lays?
Thanks
Это хороший вопрос?
Оценка 4
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Did you use original foam tape to adhere the digitizer? Or double sided tape? I've had the same thing happen to me on my first lumia 625 job, using self cut double sided tape. Since then i always have original pre-cut foam tape in stock. Not had a problem ever since. the sensor is very picky.
Был ли этот ответ полезен?
Оценка 3
If I remove some of the foam tape thats on the screen, will this fix the problem?
Оценка 0
Добавьте свой ответ
Duane будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 2,660
