Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745вопросов Показать все
replace 2009 MacBook Pro Logicboard with 2010 Logicboard?
Hi, i have here a Macbook Pro 13-inch from 2009 with a faulty Logicboard, i found a Logicboard of a 2010 13-inch Macbook Pro on Ebay and read somewhere that those two could be used in both cases. Can someone confirm this? That would be super-handy, because then i kind of would have a working AND upgraded Macbook Pro :)
Это хороший вопрос?
Оценка 2
1 Комментарий
no one can help me on this one?
из
Добавить комментарий
3 Ответов
Выбранное решение
Jonah, Sorry I just didn't see your question before now.
Generally you can only replace logic boards within the same series. In this case these are the systems within your '09 model: MacBookPro5,5. Here's is the '10 models: MacBookPro7,1.
Often Apple moves things around enough to make it hard to force fit even similar systems. I've not personally tried doing this on this series so I can't say its not possible, just be aware you're a trailblazer here.
Here's the Guides for both review them carefully before you start:
Good Luck!
MacBook Pro 13" Unibody Mid 2009 Logic Board Изображение
Инструкция
MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement
Сложность:
Сложно
40 minutes - 2 hours
MacBook Pro 13" Unibody Mid 2010 Logic Board Изображение
Инструкция
MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
Сложность:
Модерировать
1 - 3 hours
Был ли этот ответ полезен?
Оценка 3
5 Комментариев:
thanks a lot!
из
so there are no problems whatsoever? no problems with mic, webcam cable, or anything? That would be great news indeed!
из
Did you managed to make this change? i have the exact same 2 boards
из
yes i did! it all worked :)
из
How is that working @ Jonah , i might do the same to my mid 2009 Model .
из
My macbook Pro 2010 is out of order for two years due to logic board can it be replaced. please
Оценка 0
2 Комментариев:
Hi,
Both 2009 and 2010 are compatible, i did the replacement myself.
из
hi pagamim you just change the logic board? my 2009 core 2 duo model can be core i5 is that correct? thank you
Оценка 0
1 Комментарий:
core 2 duo and i5 are 2 different generations, different bus speed, different memory. Not compatible within the macs 2010 and 2009. These two will take only core 2 duo processors
из
Добавьте свой ответ
jojojonjon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 3,828
