What could be the problem?
I just replaced the screen and digitizer on my phone and touch doesn't work
Это хороший вопрос?
Это хороший вопрос?
jeyson, if you are sure that all your connections are properly seated, I would contact the vendor and replace the assembly once more. Sadly enough, it is not uncommon to receive a bad digitizer. Of course, you always want to double check your work, check to make sure that there are no bend or broken pins on the connector.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 169
