The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
37вопросов Показать все
Why won't my screen turn on?
My laptop starts and I can hear it running but my screen stays black.
Это хороший вопрос?
Оценка 5
1 Комментарий
I have the same problem so i plugged in a external moniter and it works so it might rule out the mother board. also while on external moniter i noticed the mouse and touch screen on the laptop work
из
Добавить комментарий
3 Ответов
Выбранное решение
This is probably a symptom of a broken screen, it may also be due to a loose connection or issues with your motherboard. Refer our troubleshooting guide for more help on this issue.
Asus X200MA Troubleshooting
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
There's actually no "guide" in your link above. It just stated the cause of the problem but didn't give the troubleshooting steps to be done. I badly need to fix it. More help pls?
из
Наиболее полезный ответ
Also, check the battery, it may not be charged. You might just need to plug it in!
Оценка 2
Check RAM
Оценка 0
Добавьте свой ответ
Luca будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 7
За всё время: 3,252
