Why won't my device connect to the Bluetooth?
My Bluetooth device will not connect to my Air Raid. How do I connect?
Это хороший вопрос?
Это хороший вопрос?
the sound mind i turn it on and connect to it. phone showes up increrect pin or passward how do i fix this
Был ли этот ответ полезен?
I have this problem too and idk what to do.
conect your phone and headphones to the computer and turn on and off ur headphones couple times it will detect your phone .it happend to me and fixed it this way.i hope that help
I have a samsung s6 and to fix I held to power button on the soundmine until it was flashing red and blue, then enabled quick connect on my phone.
Hope this helps.
Hit "forget this device" and search for bluetooth devices again.
Mine won't connect to my blu phone it keep asking for a pin code
Try 1234 or 0000 those are default for most electronic accessories these days.
In order to connect the Bluetooth-enabled Air Raid to your phone, Press the center button on the Air Raid. After making certain that the other audio device Bluetooth is on, the LED light should flash a blue light once every 5 seconds as long as the Air Raid is connected.
If you want to write a guide it would be welcome. This is not the way to do it.
you can go to Skullcandy Air Raid Troubleshooting for more help troubleshooting
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 14
За всё время: 58,361
2 Комментариев
Trying to pair my Soundmine to my Samsung phone but get an "incorrect passcode" message. HELP!
из debb7710
How I connect my skullcandy in my MI note 3 ? It's some issues while I am using . Sounds has automatically up and down ? What I should do for it ????
из Jaymeen
