Released in April of 2006, the S4011 was built for everyday tasks such as word document processing and internet browsing.
4вопросов Показать все
want to upgrade wi-fi card
The wi-fi card on my A105 works, but is slow. I see that there are "N rated" cards available for as little as $20 but I have no idea if they will fit in my A105 model. Is there a standard for factor (size, shape, number of "pins," etc) for all wi-fi replacement cards? if not, how might I go about getting the proper card? Thanks in advance! Jami
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
I think your best bet here is to use a USB WiFi adapter Vs trying to upgrade your internal unit.
Here's a good write up on the very latest 802.11ac adapters: Tested: We push six 802.11ac Wi-Fi USB adapters to the limit. Depending on your OS version you may not be able to use these in which case you'll need to checkup the older 802.11n adapters.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jami Francis будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 237
