1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
191вопросов Показать все
I like to know how to turn on my MacBook air without keyboard
hello I am very proud of this website I looked everywhere I have not found I like to know how to turn on my macbook air model A1370 mid 2011 without keyboard
Это хороший вопрос?
Оценка 3
1 Комментарий
You are looking for the power pads on the A1370?
из
Добавить комментарий
2 Ответов
Выбранное решение
men, use the power on pads. Bridging those two pads should power on your MBA unless there are other issues with it.
Был ли этот ответ полезен?
Оценка 8
1 Комментарий:
This was super helpful. Thank you ❤️
из
Hey men
What is probably the easiest way to do this, would really be just to remove the MacBook’s battery. If the battery isn’t present the power button becomes disabled because your power runs from the charging brick the MacBook came with. So if you connect the MagSafe connector, the Mac turns on instantly. If you disconnect it the MacBook kills because there is no power.
Hope this helps!!
Оценка 2
Добавьте свой ответ
men будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 1,892
