The iRobot Roomba 655 Pet Series vacuum manufactured in 2012. Costco exclusive.
29вопросов Показать все
Why will my Roomba not charge?
I placed my Roomba on the charging station and left it there overnight. The next morning I tried to run the Roomba through a cleaning cycle, and it gave a low battery signal.
Это хороший вопрос?
Оценка 15
22 Комментариев
where can I find replacement parts, such as lint trap etc.
из
pls reply asap
из
Roomba website has all the parts. You may pay by paypal.
из
My Roomba does not dock or charge either it's clean and 3 months old!! I'm mad I paid $500. For the darn thing!!
из
That is what mine is doing I paid 700 for mine! Did you get it to work again?
из
Показать 17 больше комментариев
Добавить комментарий
7 Ответов
Выбранное решение
The contact points on the Roomba may be dirty. Roomba's charging contacts are under the front bumper of the robot. This means that they are in front of the brushes, and see a lot of debris. They can easily get dirty and increase the resistance in the charging circuit.
If after cleaning the contacts, the Roomba will still not charge correctly, you may need to replace the battery or get a new charging dock.
Был ли этот ответ полезен?
Оценка 18
17 Комментариев:
I've clean contacts on both the roomba and dock. It has a new battery (only used once since install). Dock is working. Any other suggestions would be appreciated.
из
I have the same issue. New battery, dock has green lights, but Roomba is still flashing red after several days in the dock. Everything is clean on the Roomba and the dock.
из
Cleaned the contact points, worked like a charm thanks! :)
из
Tried cleaning the metal connectors. Did NOT work. Any other suggestions
из
Показать 12 больше комментариев
You have to clean the contacts on the dock and the Roomba. Try using something abrasive like a Brillo pad. Like this:
https://m.youtube.com/watch?v=ItVt8RM6BB...
Оценка 6
7 Комментариев:
Check the contacts on the charger. They are essentially spring loaded steel so they will push up and make contact when the Roomba is docked. I had one that was stuck down so wouldn't make contact.
из
I checked the dock with a voltmeter to make sure it was not the dock. Although the contacts all looked shiny and clean, I went over everything with an eraser and followed up with alcohol. Still no luck. Finally broke out the steel wool on the roomba contacts and it's working like a champ. Thanks Tarek!
из
Lightly scrubbing with steel wool did the trick for me!
из
Here's a great DIY fix for a Roomba that won't charge.
из
Should the charging light (orange flashing battery on 880 model) come on even if the contacts are dirty or not connecting? They look clean to me.
из
Показать 2 больше комментариев
I have to stick something like a coaster under the back of mine so it will charge. All points are clean & battery is fine. It just won't align properly.
Оценка 2
3 Комментариев:
same here, have to prop up rear of roomba to get it to charge.
из
try cleaning dust from under the wheel
из
I'm glad I saw this comment. I was about to buy a new charging station, but this worked perfectly.
из
It could also be an error with the hardware and the triggering of the pads below the roomba. A great forum thread about fixing it can be found here:
http://www.robotreviews.com/chat/viewtop...
Оценка 0
1 Комментарий:
New to this today. After difficulty docking, finally moved station, but nothing happening although it says charging. Does nothing flash while charging Never seen anything but blue when it tried to go home and white. Just sitting there .. not sure it is charging
из
Try on a hardwood floor. Mine was not charging on carpet but when moved to hardwood / like new.
Оценка 0
2 Комментариев:
Do the roomba can connect to app?
из
Model Roomba 655
из
There are a few reasons why your Roomba might not be charging.
One possibility is that the charging cable is not properly inserted into the charging port on the robot. Another possibility is that the battery is damaged or the charging port on the robot is defective.
If you think the problem might be the charging cable, try using a different charging cable to see if that solves the issue. If you think the problem might be the battery, you can try replacing Battery.
If you are still having trouble getting your Roomba to charge, then contact with irobot or explore more about this issue from here
https://homespoiler.com/roomba-not-charg...
Оценка 0
Where’s the battery located and how do you get the battery for one?
Оценка 0
Добавьте свой ответ
Rhett будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 64
За последние 30 дней: 262
За всё время: 234,121
