Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Fixed water damaged iPhone iTunes error 9?
Hello everyone.
I purchased a week ago a water damaged iPhone 6 (it has a little crack on the glass too), the device didn't turn on at all. After cleaning the Logic board with contact liquid and changing the battery with a New one, the device fortunatly did show some sign of life!
Now the problem is, when I turn it on the apple logo appears for 2 seconds long and then I get a black screen with backlight on. I tried connecting it with the latest iTunes version (it says the iPhone is in recovery mode) but trying to restore it is unsuccessful due to error 17. I tried to restore it with my laptop with an older version of iTunes and after starting the restore iTunes gives error 9 (hardware problem I suggest) and the iPhone screen gets red for a second. I tried kicking it out of recovery mode with iReb and iReboot but it keeps looping the recovery mode.
Any ideas/tips on how I could fix this before giving up and re-selling it? Thanks in advance.
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
Выбранное решение
Have a look @ http://forum.gsmhosting.com/vbb/f933/iph...
Good luck.
Был ли этот ответ полезен?
Оценка 2
Hi,
Mostly it happens because of U2 IC problem so change it and give it a shot.
Or
Since it is a water damaged device then try to Red screen solution ,
I'm sure it will work.
Good luck
Оценка 0
I had the same issue which you have, i don't know if you have already solve it or not, but i solved it!!! Follow this video https://www.youtube.com/watch?v=chZSdY5H..., i didn't work for me for the first try, but after trying a couple of times it worked!
Оценка 0
1 Комментарий:
The link is dead. It says that the video is unavailable. Can you give details on what the fix was? Thanks!
из
Добавьте свой ответ
iKatia будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 5,715
