Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
1233вопросов Показать все
I've just got finish replacing my screen
I replaced the screen on my iPhone 5c and all I see is a black screen and white lines going down the left side of my screen.I can still turn my phone on and off but when I turn it off I don't see the "slide to power off" or the Apple logo when I turn it on. I just see white lines. Also, I looked at my digitizer and my LCD cable and they look completely fine. I also hear the snap when im connecting them to the logic board. So, I have no idea what can be wrong with it
Это хороший вопрос?
Оценка -1
1 Комментарий
Can anyone help me or tell me what they think the problem could be.
из
Добавить комментарий
4 Ответов
Выбранное решение
kobe, something like that
can be caused by a bad digitizer connector
like this. Check the ends of the connector. The plastic of the connector has been compressed into the connector, causing it to flare out and preventing from making proper contact.
Был ли этот ответ полезен?
Оценка 1
It could be a faulty display order a new display and fit it and see it it works.
When you switch the phone on can you still call the phone and it rings?
Оценка 0
Possibly the LCD flex ribbon connector is the problem, check if it's dirty or damaged. Or you'll have to buy a new replacement.
Оценка 0
These guys are right---bad displays are really common. You'll have to rule that out first before looking for board damage which can also cause this.
Оценка 0
Добавьте свой ответ
kobe будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 129
