Dell 3007wfp Monitor starts flickering after a few minutes to an hour
The Dell 3007wfp monitor starts flickering (horizontal lines / blinking) after a few min to an hour of usage.
I 'think' it may be a heat related issue since the back of this monitor is cooler then another monitor. If I turn off the monitor for some time and turn it back on it again works well for a short period of time.
I have tried switching to a different graphics card and DVI cable with the same results.
Are there any heat-sinks or other parts that may need thermal grease re-applied or something else that would cause the problem.
Это хороший вопрос?
3 Комментариев
You definitely want to take a closer look at some of the caps. there may be heatshields on those. the symptoms are consistent with overheating caps.
из oldturkey03
This is dead topic, but had similar issue with DELL P2417. Issue was caused by Boost converter on display board (not PSU or motherboard) overheating, so your assumption here is correct. But the reason for overheating was different: If input voltage walls before threshold, it starts consuming more power, causing voltage drop to increase etc. This load mode caused degradation of the fuse on the same board. Replacing this fuse fixed the issue for few years. Now issue is back, replacing fuse did not help. Will try to fix it later and post updates
из Yury
Update: replacing fuse in comment above - shorting it with thin wire (did not help). Removed fuse, powered panel directly from bench power supply - worked fine (tested for 2 hours). Soldered in proper fuse instead of thin wire - works fine for now (few hours)
из Yury
