The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Note 3 imei certificate fail
I can not make calls or receive it says fails to register on network I upgrated also to version 5 . The phone was root before and also was having the same problem ( I try and manual to register it finds the local providers but it's fail to register , I try and few SIM card )
When I try the code *#0011#
The
Imei certi : fail
Это хороший вопрос?
Счет 6
Добавить комментарий
4 Ответов
i am having the same issue if find how to fix it pls send me a way on my email and ty my email anas_mukresh_1996@hotmail.com
Был ли этот ответ полезен?
Счет 0
1. Please make sure the email account is correct when you registered samsung account.
2. Land on the email, check the junk mail, check whether the validation email be intercepted.
Счет 0
my phone imei null..phone is root
Счет 0
Buy a chimeratool 3 day license. Activate usb debugging under developer options(tap buld number about 7 times). root the phone and after that do imei repair with the original imei under the battery.
other alternative is to make a new falsh with odin. you can get the firmware from sammobile . this method will delete all your information so make sure you do a backup first.
Счет 0
Добавьте свой ответ
christis1975 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 17
За всё время: 5,924
