back breaklights dont work,all other lights do. not a fuse or bulb.
need wiring diagram or hints to the problem.
Это хороший вопрос?
Это хороший вопрос?
The brake switch is located behind the brake pedal attached to the push rod..It could be faulty or stuck. Because its an important component I would replace it even if you find it's just stuck.
The Diagram is on this page...
Был ли этот ответ полезен?
Can see the diagram third brake light works nothing on the rear.
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 553
Would the thrid brake light stll work with the brake switch blown?
из Roger Blankenship
