Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577вопросов Показать все
Home Button ribbon cable
Hi. My home button has not been working properly (as in it only works sometimes but not all the time). I oppened up the ipad because i needed to replace the screen anyway and foung the home buttons ribbon cable is slightly torn. Is there a guide for previous apple device that could be applied to replacing the cable?
Thanks in advance
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi Nick
try this iPad Air Wi-Fi Case Button/Cable Replacement
http://makemoneyrw.com/WIN-AppleiPadAir
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thanks this really helped
из
The information about getting the home ribbon cable apart at the home button is not there. Needs more information between step 43 and 44.
из
Этот ответ изначально был на другой вопрос.
The button is separate from the cable, on the back of the digitiser you'll see the home button bracket just use a metal spudger to break the clue holding the bracket to the digitiser, the button will now be left, your replacement cable will likely come with the bracket attached so just connect to the logic board and glue the bracket to the digitiser positioning it correctly over the home button.
Оценка 0
3 Комментариев:
The cable I received has no bracket with it.
из
you can remove the cable from the bracket by picking it off, its only glued on.
из
There is a bracket between where the old home button ribbon cable and home button switch. I would have to try to send pix of what I refer.
из
Добавьте свой ответ
Nick071 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 116
