1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192вопросов Показать все
cannot find the power on pads 820-3024-B
I cannot for the life of me find the power on pads for my particular MBA a1370 with logic board 820-3024-B. I can find the power on pads for others similar to mine but the logic boards are different. I need to test if its the power button causing my air to not turn on. If anyone has any knowledge of this motherboard please help me in finding this jumper. I have searched for hours and no information on this board is around. I will upload some images.
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Выбранное решение
jesse, here you go after all those months :-) Remember that these are only to debug the system and not a substitute for the normal power-on procedure.
Был ли этот ответ полезен?
Оценка 3
power pads are your charger, this board is supposed to turn on by itself when charger is attached.
Оценка 2
Finally, a picture of the same board I have. I can tell you it is not the two pads just to the left of the pogo pin and green surface mounted component in the lower left corner of the top picture. My A1370 won't turn on due to very minor (I swear) spill of plain water (oddly, the power button and caps lock key are broken: the most essential and most useless keys on the keyboard) and once on it turns itself off randomly, so I've resigned myself to the $755 flat fee repair. So I had nothing to lose by shorting those two pads; however it gave off a spark that pitted the surface of the tweezers I was using, and no turn on. Off to Apple.
I can still start the mac by disconnecting the battery and connecting it to adapter power without the battery connected. But the battery connector is probably engineered for a very limited number of insertion cycles, and of course you need to unscrew all the tiny bits to take the bottom off.
Оценка 0
Добавьте свой ответ
jesse будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 969
