Trying to use the A1521 to extend my network
I have replaced my A1521 with a new DLink DIR-890L as my primary wireless router. My older Airport Extreme Base Station hopped on and exteneded DLink wifi network allowing me to network printers via Cat 5 cables. My newer Airport Express acted in kind. When I try to get the A1521 to allow me to "Add to an existing network" it announces that it can't locate any base stations. I don't understand why the newest apple wifi tech I own will not join the same DLink wifi network the older Apple tech hopped onto. Please help. I need the network ports on the A1521 for other non-wifi hardware. Hard reset has not fixed the issue.
Это хороший вопрос?
4 Комментариев
i have the same issue! extending my DIR890l with my airport express
also tried using an other extender, who wil find only the 2,4 netw not the 5ghz
please advies
из petersalciccia
@Peter - Did you download the either of the Apps I've posted below? You do understand 5.0 GHz bands don't not offer the same distances as 2.4GHz bands. Rangel extension (WiFi to Wifi) does require two different bands to be effective. You may want to look at extending your wired network a bit to hookup your second AP Vs having it going over the air.
из DanJ
Dan,
thx for your reply, but my Airport express is located next to my router, so distance cannot be an issue
из petersalciccia
So how many apple branded routers do you have?
из Aiden
